Mastreb
I think it’s time for me to chime in.
I live, work and sail in Greece.
The Mac was not my first boat.
I have sailed all over the Aegean Sea and the Ionian Sea with all kinds of boats bigger than the Mac in ALL kinds of weather. I know this part of the world very well. I am the guy with the local knowledge.
I am also an RYA Certified Yachtmaster trained in the Solent UK - if that will score points with you.
I quote Lieu Daze with his posting above. He is spot on in what he says regarding sailing in Greece.
I also quote Frank C (in the thread that Hamin’X helpfully pointed out above) in his description of the Mac’s abilities and limits. I agree with him totally and the Mac features should be taken seriously into consideration.
Further to all the above I wish to remind you that the Mac is factory rated as being a Category C vessel. It is exactly that.
If I recall well Cat C means it is built to sail/cruise in winds not exceeding Force 6 (26knots or 30mph) and waves not exceeding 2 metres (6 feet). I think that we Mac owners all agree that anything above these figures makes it very demanding on the skipper’s skills and calls for prudent decisions and great seamanship. In my opinion in extreme conditions the Mac continues to be a safe vessel that will stay afloat but becomes very difficult to handle.
I have not chosen to go out in high winds on the Mac but, yes, I have been caught out in a Force 7 and, once in a while, in winds and waves in excess of Force 7. In these extreme, for a Mac, circumstances you forget about the sailing aspect and focus on just motoring in displacement mode with ballast full, all appendages down (both rudders and two thirds of the keel), making slow progress towards the next closest safe haven; throttle in hand, steering up and over the big waves and not complaining about being totally drenched (smile) with every wave that comes over the side. In these conditions, the sailing/cruising adventure transforms into a struggle to overcome the elements and make it safely to your shelter.
Note: This is where a big engine contributes immensely in getting you there safely and reliably. The big outboard is not just about high speeds in calm waters . . . .
Conclusion: if you are not a blue water sailor with prior experience on bigger boats, don’t go out on a Mac in the Aegean and the fierce meltemi winds. Don’t underestimate the Aegean because it looks like a dot on the map compared to the Atlantic Ocean for example. The Aegean is a very challenging sailing ground with a wave pattern that is brutal.
Secondly, coming back to the issue of shipping a Mac to the Med, I want to warn you of the laborious, time consuming, beaurocratic procedures in this otherwise beautiful country that are off putting to many that are used to simpler rules in their part of the world.
It can be done, but is it worth it? I think the answer depends on your priorities and how much use you will make of your boat here.
If for six months – a whole summer season – it may be worth looking into; study the relative laws very carefully and try to determine what it will cost you before you make committments.
If just for a couple of weeks, or three – no way.
I think that your best bet would be to charter a bareboat sailing boat. If you are not so experienced go with a flotilla and follow the leader on a 30ft or 30ft-plus fixed keel sailboat that will be more forgiving if you get caught out in strong conditions.
Alternatively, you can skip the Aegean first time around and start with the Ionian Sea and the beautiful Greek islands west of the mainland, that, as a rule, does not have such strong winds in summer.
If you are an experienced sailor, I would also consider a swap if you can find an owner willing to participate in such a plan.
If you have limited experience in blue water sailing, go for the flotilla let someone else take over your worries and make the plans and you can just sip your drink and have a hassle free great time. And in the end leave everything as is, walk away and fly back home to your Mac that will be waiting for you intact in your back yard (smile).
Hope this helps.
Octaman
