Assumptions: I live in San Diego, where leaving your gate valve open will completely dry out your ballast tank and freezing is something that can only be accomplished with machines.Doupirate wrote:The aft valve is not located at the ballast lowest point.
I pump out 1-2 gallons of water every autumn. If you do not pump out that water, the ballast will not dry out even if you leave the aft valve open. The water will just freeze.
You have to evacuate the water and allow for or force a draft in the ballast if you wish to keep the fiber surface dry. Leaving a single valve open will not do it. Without a draft, the water will evaporate then condense inside the ballast, but will not leave it.
But that said, I can't think of any problems a small amount of frozen water in the ballast tank would cause other than to discourage critter habitation.
