Henry I believe you will find that Very Very Few, Showers have been installed.. It takes no less than a lot more water carried on board.. and ya might want it heated a tad.... and then there is the cost and the labor of Pumps and the Drain etc etc and added humidity.. Hummm ? For some with the head aft you make the rear berth at best... a PITA to access.. That is at it turned out , was the entire reason ....for a previous member advocating V Berth Sleeping arrangement and the potential shower modification ( one he never installed!!) He did install a toilet paper holder , with IIRC 2 face tape??? I use the shower at our marina or when I am OUT.. I have a 5 gallon solar bag I use for hot showers..
The Cockpit on The M is for sure smaller than the X.. But even on the X its not palatial.. Depending on your numbers on board and your height? You may find the little bit smaller Cockpit allows you to support yourself when heeling .. But if you Need to sleep in the cockpit? The X's additional length will be greatly appreciated.. It was argued here for a couple years by a very few , that when Rogers sales dropped off and he came to realize he couldn't sell the M he would be changing back.. That Never Happened..
It comes down to.......Money.. How Much Are You Willing To Spend..Apples to Apples you will not buy an M as cheaply as you will buy an X..
Very Very Few.. X's have the New Big Prop Motors.. Most will have a 10 to 15 year old 2 stroke, small prop , motor with? Only GOD knows how many hours on it.
That could cost you? In or around $4000 to Over $7000 to replace in a month, a year, 2 years?? If That Boat isn't absolutely pristine ? Chances are the motor wasn't well cared for either..
Dagger Board -V- Swing Keel for shallow water sailing.. Sounds good? I dont know that its true.. I sailed/powered for 6 1/2 weeks everyday in around and through some Very Skinny water.. I grounded Once.. under sail.. and a couple times under power.. THEN I realized ( Thank You Highlander!) You very seldom need all that DB to be down.. and you'll go Faster..
M Cabin Ladder........ There is a VERY Neat Mod for a swing away ladder now.. I have a fellow willing to make the pieces out of SS Brass Bronze or a Plastic ( I forget the name it starts with Mal??)
andarlite wrote:The bigger head in the
would be more important to us because it's size (for most people anyway) and the fact it's enclosed allows you to mod in a shower easily. That's very important to the admiral (and you gotta keep the admiral happy).
Regards,
Henry
