Plan of Macgregor M saloon Table
r.fairman
Post by r.fairman »
Does anyone have an accurate Plan of the Macgregor 26M saloon Table that I can have
regards
richard
RobertB
Re: Plan of Macgregor M saloon Table
Post by RobertB »
Do you just need a drawing of the existing table? Or is this something other than stock you are looking for? If stock, I can measure mine, should be easy.
r.fairman
Post by r.fairman »
I need the dimensions of the stock table the shape is some sort of trapesoid
thanks
c130king
Post by c130king »
Image Image
I am about to drive over to the marina for day of potentiallly rainy sailing. I will take some measurements. But my Dad and I remade the table from my :macm: . It is exactly the same size but over 2" thick as it has a lift top for storing charts and paperwork inside. And it has fiddles on the edge. I had intended to get a sheet of plexiglass so I could put a chart on the table and then cover it with plexi...the fiddles would hold it in place. But I never did that.
Sailing on König
mdeane
Post by mdeane »
c130king wrote:Image Image
Sailing on König
Can your tabletop design still be used as the starboard berth filler board?
Marc 8)
mdeane
Post by mdeane »
r.fairman wrote:Does anyone have an accurate Plan of the Macgregor 26M saloon Table that I can have
regards
richard
My 2005 M tabletop is 39 1/2" x 30" . The front corners are 8" radius quarter rounds.
Marc 8)
c130king
Post by c130king »
mdeane wrote: Can your tabletop design still be used as the starboard berth filler board?
Marc,
I don't think so. I have never put the original table or the new table in that position...and I don't have the cushions for it either. But the new table is probably about 2 inches taller/thicker than the standard table and that is not counting the 1/2" high fiddles.
