I purchased my 2011 blue hull
Ron
Miss Dallie
jbousquin wrote:Hey Ron,
Just a word of caution here: My 2011 blue hull's gelcoat, which has also picked up a lot of small scratches, is pretty soft. A professional boat restorer who has won awards for restoring antique hulls said it seemed to him that the gelcoat hadn't cured properly. In some instances, you could put a scratch in it with your fingernail.
I brought this to the attention of my dealer, who let Roger know about it. They basically said they were not going to re-spray the hull, and that the gelcoat was fine. The restorer disagreed, but I never got any farther with it than that. That said, I'd encourage you to let your dealer know about it as well, and ask them to let the factory know, too.
I've mentioned it before here: http://www.macgregorsailors.com/forum/v ... es#p240146 and Kittiwake says his 2010 seems soft, too.
Bottom line is this: Because the gelcoat is soft, be very careful when using a buffer and rubbing compounds such as Finesse It. On my boat, it is very easy to start buffing right through the gelcoat to the hull itself -- you'll start seeing little black dots coming through.
Before buffing, I would recommend using acetone on a rag to take out the smallest scratches. I'm then considering very localized hand sanding with very fine grit sand paper (1200+) to take out any others. The key is not using a buffer, which can go through the gelcoat very quickly.
I would also think twice about applying wax to your hull, as wax can trap air on the gelcoat, which leads to oxidation, which usually needs to be taken out by buffing, which might not be the recommended route for your boat. I try using a soft lamb swool buffing pad without any rubbing compound on it first to see if you can get it to shine without wax.
I'd also be interested in hearing if the fingernail test applies to your 2011 blue hull as well: just take your thumbnail, and try to scratch your hull. Do it in several places. If it leaves a mark, you know those spots are soft.
Good luck, Joe
