Here is an idea.
An A frame mast. It's stepped at the aft end of the cabin and When down, overhangs the bow as much as practical. Maybe ten feet. it should rest on the pulpit.
You fly one big roller furling genoa from the top. No boom. Hello oversized bimini!
Raising could be done by cable winch mounted in the stern. Also acts as backstay. No side stays to mess with.
You would need to "help" the mast up for the first few feet even with the winch. Don't know how lowering would work. May need to be refined.
With this system the boat could stay rigged. The foil furling gear could be gently bent in half and lashed to the part of the mast that sticks out over the front of the boat.
This rig will not point well but would be fine for off the wind work.
Obviously the hinged mounts for the two legs must be stout. Or use two stock mast base plates.
No it wouldn't be cheap
Well, the parts are actually cheap. Aluminum tubing is not that expensive. But the welding is extensive.
