Finally, I've done some sailing alone, and I must admit I have more questions than answers. And some piece of advice.
1. How do you hoist the mainsail when alone and sailing singlehanded? OK, forget hoising - how do you take it down? For me, it was PITA situation. When alone (and no autopilot), there is nobody at the helm to turn into wind. And hoisting is kind of not easy, but possible... Tricky, but possible. But unhoisting - was a huge challenge to me. To undo the trucker's hitch - in a good wind I had to use pliers to pull the top of the rope, and still I don't think I want to do it again. There were 3-feet waves, and not easy at all. I tried to anchor, and it made it only worse, because there is strong current along the shore, so the boat is in angle to wind and current, and it rocks that hard, so not safe to crawl to mast, let alone mainsail hoisting/taking down. And later when I was fighting to pull back the anchor, it was so hard, even considered to cut it... The sea current was so strong that I couldn't pull the anchor with my bare hands (only few days later I remembered that I have winches, and in theory could have tried to use them... but still doesn't look safe to me). HOW DO YOU GUYS HOIST/UNHOIST THE MAINSAIL, ALONE IN THE WIND?
2. When sailing, wind is coming at right angle, and both Mainsail and Genoa are hoisted, I have trouble to keep the boat at the course. 90% of the time, I have to apply strong pressure to the steering wheel! (When wind is from starboard, I have to push the wheel anti-clockwise, really hard! And as soon as I decrease my pressure - boat goes right... I wouldn't consider to offer my Admiral to be at the wheel, as her both hands (and all her weight?) wouldn't be enough for holding the Mac on course.
(Worth mentioning that when installing the Mercury engine, there was some Mercury black rubber-coated steering wheel as a gift from Merc, so the guys installed it without asking me. It is around 4 inches smaller than original wheel at
So, there are two questions:
- Shall I put back the original steering wheel from
- Is the need to apply such force to the wheel the clear indication that I am doing something wrong? (During my sailing training, I was on 43' boat, and I have never experienced anything like this. Of course, the wheel there was 3 times bigger, and experienced skipper to ask advice, but...)
3. The daggerboard! Am I right, that when wind is at 90 degrees right angle, then there is biggest drag, so I have to take the daggerboard all the way down! Correct? (And when sailing against wind, half down. When saining alone wind, no need in daggerboard at all?) Can this (daggerboard) be connected with previous issue when I need to apply too much power to steering wheel?
AND SOME WARNING.
When sailing in hot weather, be careful about opening the companionway hatch. The temperature was around 100F (39C?) and sun was shining. I wanted to reef the mainsail, and that wasn't easy, alone. After few tries to undo the trucker's hitch, I decided to go to galley to get pliers. I started to push the top hatch - and it wasn't moving. Some plastic parts ("rails") became too hot in the sun, and kind of "melted", blocking the sliding hatch. I saw them blocking the hatch, and I pushed harder, and harder, without any luck ... until bigger wave arrived, at very wrong time, and hatch started to slide , and next second I was flying head down, inside. That was painful, guys. Luckily, I haven't lost my consciousness. Thank God, one of cushions fell on the floor, and that saved my nose and face. Still, wasn't pleasant at all. And dangerous.
Yes, I know, I know. It is one of the stories that "would never happen to me, it can happen only to other silly people". That's what I could have thought... Just be careful even about such small issues.
