LOA with Trailer?
PdxSailor
Sailboat: Venture 23
LOA with Trailer?
Post by PdxSailor »
Hello, I'm wondering what the overall, tip-to-tip, length is of a MacGregor 26x on a factory trailer including up-rudders and engine. I'm trying to determine if one will fit in my driveway without spilling over onto the sidewalk too much and every inch will matter.
cheers
Re: LOA with Trailer?
The mast on the carrier will determine the overall length...as to things at ground level.....
stand by.....
Front of trailer plumb bobbed to 12 inch mark on tape
Rear of Mercury 50 HP shows 31 foot 5 inches marked (remember to take off 1 foot form above!!)
...and antenna/mast seems pretty close to same....
PdxSailor
Post by PdxSailor »
Thanks for the quick reply!
What Catigale gave you is consistent with my own measurements, give or take a few inches. I keep the engine tilted all the way up for trailering, and the end of the mast is just about even with it.
If you need a second opinion, I'll be pulling mine out of the canal tomorrow evening and can take a measurement.
By the way, you can retrofit your pole tongue with a fold-away adaptor for less than $100. You'd have to add a piece of braided flex brake line, assuming you have surge brakes and that there isn't already a length of flex there, but that's not expensive either.
By my measurements, you can knock two feet off the length of the tongue and coupler that way.
http://www.etrailer.com/Trailer-Coupler ... 30301.html
PdxSailor
Post by PdxSailor »
great suggestion on the folding trailer modification! that might just barely get it in there without hanging onto the sidewalk too much.
Can you wait until night and then move the sidewalk ?
Catigale wrote:Can you wait until night and then move the sidewalk ?
If that fails try moving the house ! or u could widen the driveway & turn the boat sideways on an angle :P
PS & theirs always shrink wrap ! :D
Champguy
Post by Champguy »
My :macm: hangs out into the sidewalk, but if I park it at an angle it clears the sidewalk. I just have to be really careful backing out of the garage. :o
Aaron
Headline from some local paper in Brooklyn, in (I think) 2009: "Councilwoman James sues over scratch"
I would make some effort to not have the coupler hanging out over a sidewalk. Just sayin'. :?
http://www.brooklynpaper.com/stories/33 ... _suit.html
RobertB
Post by RobertB »
tkanzler wrote:Headline from some local paper in Brooklyn, in (I think) 2009: "Councilwoman James sues over scratch"
While council-dingbat James should learn to look where she is walking (a license plate could have cut her worse), I suggest that having the trailer hanging over the sidewalk is hard to defend. If close, place an orange cone at the end of the trailer - shows you made a good faith effort to warn people.
uanhanlouee
Post by uanhanlouee »
PdxSailor wrote:Hello, I'm wondering what the overall, tip-to-tip, length is of a MacGregor 26x on a factory trailer including up-rudders and engine. I'm trying to determine if one will fit in my driveway without spilling over onto the sidewalk too much and every inch will matter.
cheers
31.5' but can be shortened by 5' with a fold away tongue. Folding Tongue adds between 500 and 800 bucks to trailer price.
