Height of a Trailered 26M
Adie
Post by Adie »
Hi,
I'm looking to purchase a Mac 26M in the UK. Can anyone give the height of the vessel when on the trailer including the mast (down) for road movement? Also, what is the width and length of the trailer? The official supplier doesn't seem to provide these dimensions.
Regards,
Adrian
kurz
Re: Height of a Trailered 26M
Post by kurz »
Height: aprox 3.2 meter
length: aprox 10.8m
width: aprox 2.4m
Crikey
Post by Crikey »
Note the 'aprox', which is standard in many highway indices. The day could be hot: the tires overinflated, etc. This means there's a certain point at which you'll balk, at that overpass signage.
Not fun to be wrong! :?
wfw13
Post by wfw13 »
Height: 3m
W.
Adie
Post by Adie »
Thanks all,
It seems I have plenty of room for the boat. I just need to think about the towing vehicle now!
I may have also found the 26M.
I appreciate the swift advice.
Regards,
Adrian
Adie wrote:I appreciate the swift advice.
Swift advice is what we do. 8)
Good advice may take longer. :|
tkanzler, adding absolutely nothing of value to this thread. :D :D :D :D :D
Perfectly good post padding, Shirley.......
u12fly
Post by u12fly »
Adie wrote:It seems I have plenty of room for the boat. I just need to think about the towing vehicle now!
Adrian
I would get something with at least a 6000 LBS tow rating... I personaly like to stay below 80% of the rated tow limit. This gives a good safety rating. The stock trailler is rated to 4200 lbs (loading for a trip can easily put you over). I added a second axle to my trailer and with other mods to the boat (which all add weight) I usually end up towing 5000 to 5100 lbs.
Chris.
I don't think there's such a thing as a vehicle in Europe with a 6000lbs. towing capacity, unless it's a commercial vehicle.
This is how they roll:
:D :D
Crikey
Post by Crikey »
:D
That's a beautiful solution for the Beetle's stability problems!
RobertB
Post by RobertB »
Crikey wrote::D
I assume you mean the old (real?) Beetle pictured. My wife has a 2004 New Beetle (5 speed turbo connvertible with ESP) that has absolutely no stability issues - my kids swear she has never lost control even when she occasionally drives with all four wheels on the ground :)
Crikey
Post by Crikey »
:D
No the old one, in the picture!
I once did a business of blueprinting aircooled vw motors. The one I had wanted to start flying at 85mph!
Killer - though.
Crikey wrote::D
Killer - though.
Karman Ghia's were notorious for lifting off at high speed. The aerodynamics would pick them right up and flip them over. Fortunately they couldn't get above 70 mph without aftermarket upgrades.
Crikey
Post by Crikey »
Ade,
The best I could say to you is to go with Kurtz's measurements, then double check your own setup a.s.a.p. The P.O. could have changed tire sizes or hitch heights or even, trailers (!). Congrats :!:
Crikey
Post by Crikey »
mastreb wrote:
Crikey wrote::D
Killer - though.
I even had my sisters euro model (square front and rear...) Carmen Ghia for a couple of years, before her ex wiped it for me. Dual carbs: it could really go. My main runner was a 2180cc Super-Beetle which could take Trans-Ams and much more (joy!).
R.
