http://www.nauticusinc.com/smart_tabsSX ... m_tabs.htm
I decided the 60lb gas shocks are the way to go for my loading, and outboard weight. You can't go by their rating chart because for a 26ft long regular powerboat the weight would be off the scale which is why they recommend the 80lb model. On the other hand 40lb is probably too light.
They have an adjustable bracket (PR500) that is used for the trolling braking mode, and is also used in a different mounting position to set them to neutral (straight back)for use with a sailboat without inducing drag.
http://www.nauticusinc.com/smart_tabs_pr500.htm
The ballast gate valve will have to be shimmed out somewhat to match the thickness of the tab hinge, which is going to run trimmed along the bottom behind its base.
I'll also have to work out the centering so I don't have interference from the rudders or the outboard.
So far, it was all I could do to take a couple of rough-in shots before my fingers started freezing (add cojones to that!), so I will add more to this description as I progress through to completion, and testing.
Feel free to chime in with any personal observations.
Ross
