I purchased this used 26X last fall and finally am getting around to making mods that are important to me. For years I had a "Shark" by Hinterhauler. It had a rolling boom for reefing the main as well as stowing the main. After selling that and getting this 26X the idea of not rolling to reef or stow was just archaic. I had toyed with the idea over the winter and finally tackled the project the other day. It was a full day of fabrication and running to the hardware but it's done. Now there is a rotating eye on the stern end and a slot in the front that allows the boom to pull back to turn and when shoved forward; locks it in place. Anyone interested in having one done, I can probably do one for you.
Yesterday I started the helm and steering cable replacement. That turned into a day long project because in the process we started fixing the huge amount of slop in the rudders. We decided to go with the new helm so that it was gear drive after hearing all the bad stories of failed helms here. Besides the idea of no tension when you let go of the wheel was grand and a simple autopilot for a few minutes to do something needing done. I will post a separate thread on this modification when I get time. Also I will post another separate thread regarding the removal of the rudder slop. That will hopefully be completed today.
From there we go on to installing the Autohelm 3000 (non sea talk) and testing that. I don't know how others have used this as my pedestal kants the steering wheel upward from 90 degrees parallel to the water. As a result it's not possible to mount the motor on the side of the starboard seat as it seems so many other have done. Besides my shift and throttle are on the starboard side of the pedestal so it simply won't work. As a result we looked at mounting it on the port side and the deck. I opted to go with the port side even though it will locate right in the tank cutout. I did not want to make any openings into the deck over the aft cabin period so the deck was out. I have 1/2 inch acrylic sheets and will make a 8 inch by 1 foot piece that will bolt to the rear of the port tank cutout. Then the motor will bolt to that. That will provide the correct placement to angle the belt as needed with the kanted wheel. So there is another post coming up with the pictures and thread for the Autohelm installation. I know I will need a new 13vdc power plug and receptical to mount since I don't have the original. I also fabricated a slanted aluminum bracket to mount the Autohelm control box since the small piece that is the bracket to mount it was also missing from the used helm purchase.
There will also be changes to run all lines aft for single handing. Fortunately the Sara Marie has a roller on the jib so that's already done.
Last year we installed two batteries in the compartment just aft of the sink box. We added a battery switch, changed out the old worn fuse/switch panel, and installed a 110vac ground fault receptical there as well. Inside that compartment we also added a DC marine automatic charger wired into the 110vac. The 110vac was fed from a new 30amp receptical mounted on the port stern and runs through a push button 30amp breaker also on the aft of the stove box. It was pretty easy mount all that since the sink cover (starboard of the sink box, black/brown plastic) unscrews and that entire thing comes out of the way.
I have just ordered a new Nicro Stainless steel solar vent/fan and plan on installing that right in the forward hatch. We had a huge nightmare this spring when we opened it from winter storage (uncovered and in a unheated building). I was flabbergasted to find that everything inside had a layer of mold. We are still working on that. We pulled all the seat covers off the foam and washed them in the washer with laundry soap. We took the sail and made a laundry soap and borax mixture as recommended elsewhere on this forum and washed it well. The main had been left inside rolled on the boom so it was stained too. Now we have the task of scrubbing all the insides with the soap and borax mixture. I hope the re-installation of the foam into the seats isn't a nightmare.
I like others have had another problem with water always laying in the space below the sink and below the cooler spot. I went and used clear silicon sealer and did all the fittings topside and around the rub rail. I checked the anchor chain locker. While working on the rudders I found one ladder bracket lose so some of the water may be coming in there. We will see how she does now that the topside has been sealed with silicone. I think most was coming in there as it seemed that it got water inside even when it was only sitting in the yard and there had been rain.
Well I am not getting anything done on the project typing here but I thought others might want to see the changes and make improvements on their system too. I will try and get some pictures on here as soon as I can.
Happy Sailing
Sparks
AKA Sparksvonrou
