kmclemore wrote:Check the line going from your sink drain to the through-hull... I suspect either the hose or the through-hull is leaky and as you heel to port you're picking up some water.
That would be my guess, too. You might try running a hose in the sink while it's on the trailer, and see if you get water under the seat again. Or tape over or plug the hole and fill the drain and watch to see if the level goes down.
My Aquarius had a cockpit drain that used a short hose to go out through the transom. It was one of those super cheap flexi hoses (white, thin). It had cracked and I didn't know it, and was actually taking on water even though the through-hull was above the water line (barely), much like the engine well drain on the
. If I hadn't noticed the water level rising in the boat in time, it might have gone to the bottom, as once that thru-hull gets below the water line with a cracked hose, there's no stopping it other than beaching the boat. Or plugging the hole. And it was a lot bigger than that little drain in the
engine well. It used a sink drain and tailpiece setup, which was 1-1/4 if memory serves.
If the actual thru-hull is shot, I wouldn't even bother trying to fix it. I'd just bore it out and install a real thru-hull. If the hose is shot, then a new hose is easy enough to put in, once you can get to it, which might not be so easy.
Or it's something else altogether.
