BOAT wrote:Hi Captain Matt.
I have only been using the mainsail in heavy waves as stability. Some here suggested using the head-sail instead. On the M boat what is the best sail to use in heavy waves?
The best as YukonBob pointed out is both sails reefed to maintain balance, but I sail under "just main" and "just genoa" rather frequently depending on exactly how lazy I'm being at the moment, and I'm just as likely to go either sail only.
It kind of belies the center of effort theory as being the dominant dynamic, because the CE is 10 feet forward when running genoa only as compared to main only, and they both sail just fine in most winds IMHO. Yes, there's better balance when both are out and reefed, but clearly CE isn't that big of a deal if you can move it back and forth 40% of the waterline length and not really have it matter on the helm. Not only are you moving it back and forth, but you're also moving it from well forward of the CLR (daggerboard) to AFT of the CLR, and the boat still handles just fine. Aft of the CLR is supposed to destroy boat balance, but every sloop I've ever sailed does just fine on main only with the CE well aft of the CLR.
So I say use whichever sail you're most comfortable with at the time if you can't use them both. Upwind in light air, Genoa because it points better on its own. Any kind of heavy weather, mainsail with a small patch of genoa because the Genoa is heavily weather affected. Beam reach, mainsail. Running, Genoa. I've not really thought about it, but I guess I'd say it just depends on what you're doing.
Because I sail primarily in light airs, I've actually considered ditching the mainsail entirely and running two drifters as roller-furling headsails, with permanently mounted whisker poles. To tack you just furl one and unfurl the other, and the whiskerpole comes around with it from a center of rotation abaft the mast. How much sail you get out depends on what you're doing. Yes, it wouldn't point very well, but Macs already don't point very well and I don't think this would be any worse. Moving the CE a few feet forward isn't going to hurt anything IMHO, and I like novel rigs. And you could get the CE just about to where it is now by making a dramatically backswept mast: The current mast lays back at a 10% angle, as if it's not fully raised. The twin forestays for the two drifters hold it in place at that position, there's an aluminum wedge in the mast foot to keep everything correctly tensioned there, and the spreaders drop straight down to the chainplates instead of being backswept. Everything is kept in tension, and now the staysails CE is two feed farther back on the waterline, right where it should be. All it requires is new sails and stays, and custom machined mast-foot wedge to properly distribute forces at the step.
Matt
