I've realized though that the rigging isn't really set up for a 150% genoa...looks like it's all positioned for a normal jib. I *think* the best location for cam cleats, winches, rollers, etc., would be on the sides of the cockpit (looks like). For those of you with a 150% genoa, where is the normal location for these items?
There are sliding tracks on both sides of the cabin top (looks like where the old jib lines must have been routed), and there are also slides on the sides of the cockpit. I can't remember if the slides are the same size or not...I'm hoping they are...if so, I can probably move at least the rollers to the sides of the cockpit easily. Are there cam cleats or lewmar winches that will mount on the slides? (Or is that subjecting the slides to too much force? I've got two new cam cleats, I just don't want to start drilling unless it's truly necessary, plus being able to adjust their position on the slide rail seems like a good thing.)
Any thoughts or suggestions much appreciated!
