26X High Performance Rudders
hamshog
I broke one of my rudders on my 26M but it was due to stupidity. I asked Joel at Ida Sailor to make me a set which he did. Best move I have made. They are made from a solid peice of polyboard, they are solid not water filled and perform MUCH better that the cheap resin Macgregor rudders. If you want better performance and not have to worry about your rudder cracking call Joel. www.idasailor.com. Money well spent.
Lynn Massingham
26M
Lynn Massingham
26M
hamshog
Lynn Massingham
26M
Lynn Massingham
26M
- Jeff S
I believe they would likely be more durable than the stock rudders, however by what metric do they perform better?hamshog wrote:I broke one of my rudders on my 26M but it was due to stupidity. I asked Joel at Ida Sailor to make me a set which he did. Best move I have made. They are made from a solid peice of polyboard, they are solid not water filled and perform MUCH better that the cheap resin Macgregor rudders. If you want better performance and not have to worry about your rudder cracking call Joel. www.idasailor.com. Money well spent.
Lynn Massingham
26M
Jeff S
hamshog
- Jeff S
I simply meant what measurement of performance are you using to say the are better than the stock rudder other than the durability. You answered the question.
I read the advertisement that suggests it generates more lift and less drag so I was wondering if you meant the rudders offered a better response or you were able to go faster overall. It is difficult to make a foil that gives better lift and decreased drag. I assume by making the rudder out of more sturdy material they were able to cut down the cross section and possibly the overall length which would reduce drag significantly. Simply increasing the lift generated by the foils would increase drag, however it may be able to achieve the same lift at lower angles of attack if it were more efficient, and possibly achieve higher angles of attack overall giving it the rudder authority that you seem to be getting.
The drag coefficient effect difference between the rudders would actually be pretty small. If your rudders were getting overpowered by the boat's weather helm (which is what I assume you meant) the motion of rounding up and falling off would be a far greater speed issue than any drag and the rudders would be well worth it in that case, not to mention the durabilty. If excessive weather helm was an issue before have you adjusted your mast rake at all?
I also noticed IdaSailor's HDPE centerboard. Anyone have experience with it? It doesn't fill with water but has 8 lbs of lead in the tip- I wonder if the overall weight is the same a water filled CB? The weight distribution being lower would seem to be better with the CB fully extended.
Jeff S
Jeff S
Jeff S
Jeff S
