Two questions:
- One thing that I've puzzled over is my motor (Tohatsu M50D 2 stroke). I have been religious about flushing it after each salt water trip. Last year somehow (even with flushing) the cooling system clogged and all that came out of the pee hole was steam. The mechanic had to hook up an air hose to the water pickup to blast out the chunks, and it has been fine since. But leaving it moored, what do you do about flushing? When you tie up after the trip do you tilt the motor up just enough to put muffs with a hose on to flush it? Or is it not a problem to just leave it? Suggestions and lessons learned?
- Seacocks. I have the two water-line level through-hulls for the galley and head sinks. I am a bit paranoid and thought maybe I should drill those out and replace them with true through-hulls and seacocks so when I'm not on the boat I can close them. Thoughts? The picture at the end of this (long) post increased my paranoia: http://www.sailfeed.com/2014/01/the-lon ... ith-blood/
And any other suggestions for "marine life" welcome.
