5mph (8kph) is max 1500rpm and thats going against current and wind, if no current or wind IMHO you should be doing a little over 1000rpm?, these boats are extremely efficient at low speeds and the honda motors are one of the quietest and most economical at low revs, much quieter than the etec.Boblee wrote:[quoteAgreed. It's quite quiet at dead-low idle. But 5mph is cruising speed, and 6 hours is a long time.
At that speed you will/should not be creating any bow wave at all and will be very surprised if it stops you hearing any other sounds.[/quote]
Thats what I came up with. I figured 1500rpm tops considering prop selection.
