Swap Meet!
- yukonbob
Re: Swap Meet!
Also jib has a small wear hole from the sock near the head an from what I remember is smaller than a dime. Main has no issues I remember.
No Control
Re: Swap Meet!
OK,yukonbob wrote:Also jib has a small wear hole from the sock near the head an from what I remember is smaller than a dime. Main has no issues I remember.
I will take the main and jib for my
Thank you
- yukonbob
Re: Swap Meet!
Thank you.hschumac wrote:FYI for all, themain will not work on an
(the M mast is a few feet taller).
Re: Swap Meet!
I have some X mast, same as the 25 and D/S I believe, smaller than the M. No idea what shipping would be.Hey Matt,
I forget..... was that mast the same cross section as the X and D? If so, would you want to get rid of a couple feet at a time?
Best Breezes,
Steve K.
I have a few dozen back issues of sail if someone wants trade for other sailing magazines.
- Steve K
- Sailboat: MacGregor 26D
Re: Swap Meet!
If you're offering, I'll measure for length I need (actually 15 to 18 inches, I'd guess) and see what it might cost to ship.
I want to make a new center support (for trailerling with mast down) for the mast, to replace that chunk of 2x4 I have there now. I bolt it into the mast step. A mast section would just look better there, I think. Can I pm you
Thanks
Best Breezes,
Steve K.
Re: Swap Meet!
Sure.If you're offering, I'll measure for length I need (actually 15 to 18 inches, I'd guess) and see what it might cost to ship.
- mastreb
Re: Swap Meet!
I know it can be retrofit, but I don't know if you need the mast foot to do it. It's likely very similar.Steve K wrote:Hey Matt,
Best Breezes,
Steve K.
I'm not going to cut it up--I don't have the tools to do it correctly. I'll happily pass it along to someone who will thought.
- mastreb
Re: Swap Meet!
PM me your address. I'll ship it and let you know the amount, which you can paypal me.budgates wrote:I could use a new winch. Mine broke Labor Day weekend.mastreb wrote:New trailer winch + 25' aircraft stainless cable and hook. Decided not to implement.
Re: Swap Meet!
Geez here I started to get all excited, then said to myself guess I,m outa this one no Admiral to swap !!
vizwhiz
Re: Swap Meet!
Mastreb, i didnt see the windex spoken for... Still available?
Is it the type that slips over an antenna, or separate mount?
