Hose clamps look good. They are stainless from the factory. I will be changing it out though with a bigger hole and and brass ball valve (again, I know this will make you guys mad but I am putting a big brass ELECTRIC ball valve in there just like I did on the bow vent so i can slam it shut in an emergency) and the only thing connected to it will be the holding tank pump out and the transom well.
I am NOT using that thru hull for the bilge pump(S) (that's PLURAL - there will be TWO of them). The bilge pumps are getting thier own thru hull probably a lot higher up from the waterline. I'm still figuring that part out and still reading Navy manuals and other crap.
'boat' will be totally outfitted for 'enviro' - MENTAL
operation with everything (except the bilge) pumping into holding tanks. I will be able to cruise Catalina, the Channel Islands, Anacapa, Canada, Washington, Oregon, and bunches of other places without fear of "the MAN"
('boat': it's not just for Mexico anymore). 'boat' will be a tree huggers delight, (tree huggers: their not just for breakfast anymore). Ever eat a pine cone?
You can't really do much for San Diego, and L.A. - after every rainstorm the entire Bay is polluted. Newport and everything north is pretty much the same. Things don't really start to clean up until you get past the Bay Area, or 15 miles offshore. That's why the holding tanks are kind of a waste for most So Cal coastal sailing. The runoff from the cities which is in the MILLIONS of gallons far out weights anything our puny little galley sinks will ever do. Even the enviro - MENTAL folks here admit that and why there are few restrictions on the coast down south. Oregon is actually MUCH more strict than California. We go to Oregon a lot.
