water resistant pocket door
DaveC426913
Post by DaveC426913 »
I am thinking about replacing the smoked plexi helm side panels with wood, and cutting out little drawers to hold doodads like a pencil and windmeter etc.
I want to figure out how to protect it from spray dribbling down the panel and into the top edge of the pocket.
Surely this has been solved before on a boat. Anybody got any ideas about how?
RobertB
Re: water resistant pocket door
Post by RobertB »
Have you looked inside the pedestal to see if you have room? Mine is pretty crowded. Also, on the :macm: , the Plexiglas is over plywood except where the plywood is cut away. I have added storage on the outside. If you make compartments as drawn, suggest drainage holes and not putting in anything that cannot get wet. Otherwise you will likely need a positive engagement latch and a compression gasket.
Ixneigh
Post by Ixneigh »
Put a batten above the hatch. 1/4 round teak or something. Have the the thickness be a bit more the the edge of the hatch. That will keep most of the water out and act as a drip edge. Good luck finding room in the pedestal. I could barely add an aux. 12v outlet in mine.
That concept might work in the cockpit combings though. I was thinking about open pockets but I like this idea better.
Those "would" need a gasket of course.
Ix
Post by K9Kampers »
Catigale did a project report on putting cubby holes in the cockpit combings.
Yea, mine doesn't have unobstructed space in there. Combing would make more sense.
I like your idea with the pocket, however keeping it dry is going to be a challenge. Love to see what you come up with.
DaveC426913
RobertB wrote:Have you looked inside the pedestal to see if you have room?
Yes, there's a few inches.
RobertB wrote:suggest drainage holes and not putting in anything that cannot get wet. Otherwise you will likely need a positive engagement latch and a compression gasket.
Yeah. I'm wondering if I'm just inviting trouble by providing a place where stuff will get wet. Or stolen.
Ixneigh wrote:Put a batten above the hatch. 1/4 round teak or something. Have the the thickness be a bit more the the vedge of the hatch.
Yeah. This is the best idea I've come up with yet.
Ixneigh wrote:That concept might work in the cockpit combings though. I was thinking about open pockets but I like this idea better.
I suppose I could use the existing holes in my combing... the ones the PO had cut so that they could install the party seats on the transom.
extreem
Location: Lake Thurmond, GA "Blew By You" 2001 X..50Hp Honda
Post by extreem »
You could always put a small spacer between the door and the pocket. That way if water gets around the door, it would not get into the pocket.
