What is the "snout" on this Mac 26M boat cover for?
- tbowers
- Location: Covington LA USA - 2006 MacGregor 26M w/ Tohatsu 70hp
I purchased this boat cover from Sail Warehouse:
http://thesailwarehouse.com/cgi-bin/web ... 6848_17429
Pic at the bottom. What is the purpose of the 'snout' that is at the front of the cover? the mast attaches to the front rail pulpit and ends there. What is supposed to slide in to this small tube area? For me it just hangs down limp. The reason I ask is because the cover is only slightly loose and if it rains it collects in the cover and sags the cover. Perhaps if something is supposed to go in this area it'll help stretch it out?
thanks
thanks
- NiceAft
Re: What is the "snout" on this Mac 26M boat cover for?
I believe it's for a roller furler. If you did, when the mast is attached to the pulpit, the furler will extend beyond the mast. This is not the best picture for showing what I mean, but I think it works well enough. Do you see how the furler extends beyond Nice Afts bow
paul I
I believe Ray is correct. If you lower the mast with the furler connected it sticks out past the mast about as far as it shows in the pic.
- mrron_tx
Mine does the same thing....and it is for the furler.... it fills it up pretty good , but leaves some wiggle room
Ron
- Obelix
When ordering the cover one can decide to get it with or without the "nose". The extension is to cover the overhang of the furler, if you don't use a furler you can order the cover without the extension (at least that was the case when I got mine in 2012).
Obelix
Obelix
Tenacious
- Sailboat: Tattoo 26
Ray is correct. I have the same cover on myNiceAft wrote:I believe it's for a roller furler. If you did, when the mast is attached to the pulpit, the furler will extend beyond the mast. This is not the best picture for showing what I mean, but I think it works well enough. Do you see how the furler extends beyond Nice Afts bow![]()
Here's a pic of my boat with the furler in the snout.
I undo the forestay at the hound and slide it back before covering. Also before trailering.
- NiceAft
Tanacious wrote: “Here's a pic of my boat with the furler in the snout”
Let us call it what it is, proboscis
I gave mine a nose job.NiceAft wrote:Let us call it what it is, proboscis![]()
Rhinoplasty. Love that word.
If u have a furler u need the Male cover , if u only have a Forestay cable u need the Female cover !!
- tbowers
Thank you all very much. When I bought my used M recently the roller furler is not attached to the mast at the bottom. Now i know.Thanks to you all .
Does anyone else have issues with water collecting in the cover? Maybe bc I use bungees and should use straps? Or do even those with straps still have a problem with rainwater causing an inward collapse between stowed mast and the stanchon wires?
- NiceAft
That's normal. Just be glad you don't get snow
Go back and take a good look at the photo I previously posted.
Some members took PVC tubing and bent them to create a support frame for the tarp. I tried it, and it worked for a couple of years, but I just did not believe it was worth the hassle.
Try doing a search under PVC. This is what I quickly came up with. http://macgregorsailors.com/forum/viewt ... VC#p290786
