What is your suggestions about that upgrade? Suzi 70 is $8000 and 90 is $9000.I have prop options as 3X14X13 and 3X13 7/8X15 for a 26
Thanks in advance,
milest wrote:Hi everybody,
What is your suggestions about that upgrade? Suzi 70 is $8000 and 90 is $9000.I have prop options as 3X14X13 and 3X13 7/8X15 for a 26![]()
Thanks in advance,
Dang!! That's awesome!Erik Hardtle wrote:Go big or stay home!!! Hhhehe....
Here is why you should go 90hp!
https://www.youtube.com/watch?v=eQafizZpamE
or this:
https://www.youtube.com/watch?v=dBPSK5m6WfE
I took a quick look at your other posts and it looks like you have been contemplating swapping out the Honda for awile.Thanks guys..
I want a quiter 6-8 mph cruising.Of course it sounds better 20 more bhp for $1K. It would be fine if anyone has tested 70 and 90 and compare them. For the same 1.5 Lt. engine, if I have benefits of that 20 more ponies after 5000 rpm it's not so important to me. Can I feel the difference 1500 to 5000 rpm? What about the prop choices that I have?
I've thought of doing something like that for cruising the Erie Canal - intentionally over-propping. But I don't travel far enough to have to worry about it, so the boat bucks go elsewhere. But it's certainly a valid idea to prop for the intended use. I use the 4-blade mainly for towing a wakeboarder (it howls at canal cruising speed). The 3-blade for 'normal' use, including canal cruising. Changing props takes minutes on the trailer, so no big deal to switch them out.Seapup wrote:At 6-8 mph there is not much slip, so over propping for lower RPM is one way to achieve that. I have read of Gemini catamarans running the BF50 way over propped for better fuel consumption/lower rpm cruise speed since it cant go over hull speed.
A problem like this is nice to have because it's not a problem - it's a matter of choiceWhat is your suggestions about that upgrade? Suzi 70 is $8000 and 90 is $9000
Unless Your 90i smaller than My 70.... at full up....it,s gonna bump the helm seatmilest wrote:Thanks everybody,
Decision is made for Suzuki DF90A......and.... Should I use transom wedge of 5 degrees for a heavy 26or not?.. Can you please give some advice for the problems about helm seat when lifting up the suzi DF90A?
Thanks so much,
