Had gone about a mile, went through a small dip at less than 30MPH, and heard the ladder tied to the post dragging. WTF? I guessed the ladder had come untied and was dragging. Fortunately, I was near an exit lane, so was able to get off the main road.
Walked back, still thinking it was the ladder. WHAT? The trailer tongue was laying on the street, the jack post had a mushroom head on it now (but it didn't break off?). One chain hook was gone--think the chain broke on that side. The other hook was straightened out.
I was able to jack the boat up, secure it on the ball, and laid under it to make sure the tang was around the base of the ball. No chains available, so towed on city side streets, creeping through each dip.
So the questions- WHAT CAUSED IT?
My most probably case is the tang did not get below the ball, but I watch for that normally and it's pretty easy for me to see if it doesn't set low enough on the receiver.
I'm wondering if it's possible that the boat "sprung up" and pulled the hitch off the ball. Neither the bow winch nor the ratchet straps in the aft were snug at all as I'd just finished bottom painting it.
I had a paddlelock in the hitch, so I know it didn't "pop open".
This X trailer (circa 2002) originally had surge brakes. Installed electric, but the surge assembly is still in place. Some action back/forth through this.
And there is some play from the top side where the surge brake piston is located, even though I've installed bolt to limit movement.
Do these things wear out? Do they need to be replaced?
I'm too nervous to do a four hour tow until I get some answers and/or new parts. Thanks for any suggestions.
Ron
