Gotta agree with Geoff there ! I got a 75HP Merc. 4S 1731CC big block eng. with EFI so has more torq than Geoff, eng. but my boat is approx 1000# heavier as she is modified to live in ! , when G went to that prop he seen a big diff. in WOT speed that I can attest to , I was running with the same other prop,s G was before & my eng. was over revving 200-300rpm,s @ wot enough to set off the eng. alarm buzzing but not enough to kick in the eng. rpm limiter , so then I went to the same prop G has now & had a significant improvement in wot speed even with the eng. problems I was developing & that time !
