WASP18 wrote:I removed the "Luff support pin" and I can't get the drum to slide up the foil.
Plan B (What do you think?) I'm going to re-attach the pin and put everything back to where it was. We could then use it strictly as a motor cruiser for the remaining six weeks in the season. I'll trailer it home late September and find someone who would make house calls on these issues.
I suspect the forestay would be ok considering that it will not be under any sailing stress.
What do you think?
If I read the manual correctly, you should undo the stopper knot that holds the furling line to the drum before you can lift the drum. Look at steps 12 and 13. Step 12 is what you want it to look like, and step 13 is what it looks like now. The Luff support pin is installed and the drum lowered in step 12. Step 13 is to tie the knot. SO, logically, to lift the drum for access to the turnbuckle, the knot needs to be undone as well. Just my interpretation.
I just replaced my backstay and sidestays yesterday, and have a new forestay to install in the CDI furler, hopefully tomorrow. I'll see what I can learn and if I figure it out I'll post the procedure. Pinning the furler during mast raising has always been a real pain but I never knew about adjusting the turnbuckle. I'll see if I can get it right.
One thing I learned from Ezra at BWY is that the little black fittings at the end of the spreaders, where the upper sidestays pass through, shouldn't be tightened all the way down and should actually just allow the stay to slide within the fitting. Mine were screwed down tight, and I put them back tight but not so tight that the wires can't slide within them. I worried about about the screws backing out so I'll place some tape over the ends to make sure that doesn't happen. HOWEVER, now that I have made the change, the spreaders, which used to just touch the lifelines while trailering, are now much lower and I had to undo the lifelines to get the mast back in trailering position. Not really sure why: at first I thought the mast crutch had somehow lowered in its hole, or maybe that the spreaders used to be under tension which held them in a different position. I really don't know. All I am sure of is that I have thousands of km of trailering with the spreaders resting nicely on the lifelines, and after the stay change that won't work anymore and I'll have to remove the spreaders for trailering.
All five stays, plus stay adjusters, pins and ringdings, came out to $570 Canadian delivered to Montreal, and so far have been very easy to install...just a phillips screwdriver and the standard 7/16 and 9/16 drivers. The fittings that bolt to the mast were already attached to the stays so changing the four sidestays and the backstay was a matter of only a few minutes. Took longer to get the mast off the boat than to do the actual work. The old stays have some serious permanent kinks in them.
