halyard for CDI FF2 Furler
Locked
Don
Post by Don »
I have a 97 :macx: with a CDI FF2 furler and I need to replace the halyard, part of the line is de-corded. What should I use and where do I find it?
Thanks
mike
Post by mike »
I don't know what's involved in de-coring a 1/4 line, but your best bet is probably to just call CDI and purchase a replacement from them.
--Mike
Graham Carr
Location: Sedro-Woolley WA, 2002 26X , Mercury 50hp 4 Stroke Bigfoot "Pauka2"
Post by Graham Carr »
Are you referring to the 1/4" halyard with the ferrule attached that runs in the luff extrusion? If so you can find the replacement part Here. You can download the PDF manual Here. If you are referring to the furling line, you will need 5/32 to 3/16 line. CDI recommends braid on braid decron. I used 1/8 cord from the locale hardware store. You can find the instructions to rewind the drum on page 10 of the manual. Both are easy to replace. You will find a dealer list link on the above sites (here).
Graham
Bill at BOATS 4 SAIL
Sailboat: MacGregor 26D
Hi Don - I have the CDI FF2 Halyard, 1/4" x 34' w/ferrule - list price $60.
I'll let you have one for $50, including shipping.
Don
CDI Furler halyard
Post by Don »
Bill Thanks for the offer, I'll contact you when the time comes. Upon inspection I find that the halyard is ok just stretched. The "messenger" [CDI's term for line to raise the sail] is in bad shape. What would you use to replace it?
Just about any piece of line will work, that's strong enough.
Locked
