Gazmn
Posts: 1129 Joined: Wed May 31, 2006 10:22 pm
Post
by Gazmn » Sat Nov 14, 2015 4:27 pm
I'm having an "Oh $H!t" moment.
I lost that half nickel sized widget that locks in the steering wheel
Who, how & where can I get another one...
Anyone
Ixneigh
Posts: 2462 Joined: Thu Sep 09, 2010 11:00 am
Post
by Ixneigh » Sat Nov 14, 2015 4:44 pm
Make one? Ss washers cut In half in a pinch?
Ix
Posts: 8299 Joined: Thu Oct 11, 2007 12:01 pm
Post
by Russ » Sat Nov 14, 2015 5:01 pm
You talking about this thing?
Gazmn
Post
by Gazmn » Sat Nov 14, 2015 5:10 pm
RussMT wrote: You talking about this thing?
Yep
Spector
Posts: 266 Joined: Sun Jun 10, 2012 6:53 pm
Location: Calgary AB, 98 26X 'Cenoté' 2002 Yamaha 60 HP
Post
by Spector » Sat Nov 14, 2015 5:18 pm
Woodruff key..any bolt supply house should handle them
Gazmn
Post
by Gazmn » Sat Nov 14, 2015 5:36 pm
WOODRUFF KEY!!
No Wonder I couldn't find it Thank You!
Gazmn
Post
by Gazmn » Sat Nov 14, 2015 5:47 pm
Any clue what size we use???
Posts: 6256 Joined: Sun Feb 08, 2004 9:24 am
Post
by kmclemore » Sat Nov 14, 2015 5:58 pm
Most Home Depot / Lowes / Sears Hardware will have hardware bits bins and they often have Woodruff keys. You need one that fits in the slot you have, so measure the width of the slot and that will tell you what size you need.
seahouse
Posts: 2182 Joined: Sun Dec 07, 2008 9:17 pm
Post
by seahouse » Sat Nov 14, 2015 8:45 pm
Hey Gazmn!
Note that in an emergency you might be able to reassemble the steering wheel without this key and still have functional steering.
I have never had this apart on these boats, but that is assuming the wheel is also on a locking taper that will snug up when a nut is turned. The Woodruff key / keyway/ keyseat is used to hold an index in one position and to absorb any torque that is beyond what the friction in the locking taper will absorb, so abrupt steering inputs will need to be avoided, although some turning/ slipping would not be catastrophic.
Gazmn
Post
by Gazmn » Sat Nov 14, 2015 10:38 pm
Thanks Guys
In a few hrs I went from uh oh!... To Oh... ok I can fix this - & get extras
As always, you guys are GREAT. I learned What the Hull the thing is called & Where I can get it. Who's better than u guys?
Nobody
Posts: 6135 Joined: Tue Jul 05, 2011 7:42 am
Post
by Tomfoolery » Sun Nov 15, 2015 6:58 am
For quick results, your best shot is a True Value or other franchise hardware store. I don't recall ever seeing key stock (straight) or Woodruff keys in a BORG, but every good hardware store stocks them in a variety of sizes.
shrektruck
Posts: 19 Joined: Mon Sep 14, 2015 4:41 pm
Post
by shrektruck » Sun Nov 15, 2015 4:56 pm
New to sailing and I saw the title and thought I'd better see what a ''Winslow key'' is. Ha ha, True Value or Napa is probably your best bet.
Post
by kmclemore » Sun Nov 15, 2015 5:03 pm
! kmclemore: Changed the title to make it a bit more searchable in the future.
Gazmn
Post
by Gazmn » Wed Nov 18, 2015 8:13 am
Thanks Mod,
Kev you & The Boys do a great job. For Free
Thank You
Post
by kmclemore » Wed Nov 18, 2015 10:49 am
Gazmn wrote: Thanks Mod,
Thank You
Thanks! Nice to hear a little kudos once in a while.
