Found a Blue Sea 1830 SoC M2 meter on eBay at a good price and installed the day before leaving for a 3 week trip to the BVI again.
Nice Big Shunt. Used a couple of ty wraps to fix to battery handle and two sided tape to battery.
Shunt goes on the Negative side of battery. On the Positive is a Blue Sea 30 Amp Fuse.
Installed here. At first the amps in/out arrow was pointing the wrong way, just reverse wires on the shunt.
Setup was easy, Battery is a West Marine 105AH AGM about 2 years old so set it up to less AH about I think 95 AH. When charged to 100% input that to Meter.
What I like best is the ability to see how the batteries behave and how many amp various equipment and different modes of operations use. Like Motoring, sailing, sailing at night or at Anchor. At what time Battery reaches 100% etc.
A Few Examples: Charging.
Motoring : Saw 10 to 12 amps max at 6 knots
Motor: On at idle only 5 amps there or less.
Solar 140 watts with good sun 9 amps /battery 100% about 1pm from average of 78% overnight
Discharge Examples :
Engel 2.4 amps when running
Autopilot, GPS, Depth Sounder, VHF : 2.5 to 3.5 amps
iPad .4
Cabin LED lamps .2 amps each
LED Running Lights .5 amps
Surface RT 2.2 amps (Surpised me that did)
Laptop on Inverter 2 amps
Also noticed when solar starts to kick in the morning the Yandina Combiner would close and 10 amps would come from the Start battery to the House battery then fall down till the voltage on the start would fall below the close value and open the Yandina Combiner.
