The water pump, however, doesn't have a seal on the top cover where the shaft comes out. Presumably the impeller is the seal, up inside the metal 'basket' it runs in, like the metal plate on the bottom. Except that there are gaskets and an o-ring for the lower housing to the aluminium casting, where the bearings are. And gaskets between the pieces. But no seal for the shaft at the top, either in the parts book, or in the new cover, or the old covers.
Does this seem normal to everyone? Anyone ever change the impeller in a BF50? I can't find an answer on the web, nor on youtube vids.
So I made my own short video, showing the water peeing out the drain holes on the sides, and in front. Just doesn't seem right, though I'm no OB mechanic.
And some poor video, but it should give you an idea of the amount of water coming out those holes.
https://www.youtube.com/watch?v=-D9YWhBF1Xk
