xxx
JohnCT
Sailboat: Venture 21
xxx
Post by JohnCT »
xxx
Calin
Re: Measuring rigging
Post by Calin »
Hello John,
If it is an inch difference I would not worry. It would be more concern with rake and stays tension.
THE CUSCUS
Post by THE CUSCUS »
Have you measured the positions of anything else, port and starboard? Nothing measures the same on my V25. And for that matter, no 2 boats are likely the same. I think they were all built "by eye". Not that this is a bad thing, one just can't assume that both sides are the same.
JohnCT
Post by JohnCT »
xxx
Retcoastie
Post by Retcoastie »
The differences you have are probably not a problem. It may be that one of the stays was replaced with not an exact match. That is what adjusters are for. Unless you suspect a structural weakness they are most likely fine. The main thing is that the mast is vertical and straight port to starboard. You could use a spirit level to level the boat and then a plum bob to check the mast.
JohnCT
Post by JohnCT »
xxx
Postby THE CUSCUS » Fri Sep 09, 2016 2:19 pm
More like built by hay Karumba
(Edited and quote added to clarify reference to earlier post)
JohnCT
Post by JohnCT »
Xxx
Not quite sure how I insulted people on this thread, but got a PM to that effect.
My apologies to those who took offence, I added the quote to which the post referred for clarity above.
Per forum rules, lets close off that discussion here, please.
