It's basically a wheel for your boat - it works the same way the cable works on our helm only instead of a wheel it has a stick. Also, our wheel steering has a rack and pinion in it so you must turn the wheel like three times to make a turn but the stick steering does not have a rack - it's just a direct cable to your steering arm - so you pull the stick a quarter turn and you get a full turn out of your steering.RussMT wrote:BOAT wrote: Or even better - install one of these remote steering arms that Highlander found:
Hey BOAT, what is this steering arm you speak of?
My idea was to have one of these connected to one of the steering arms below decks as a secondary steering system - perhaps not connected all the time but only when I want to steer the boat from inside the cabin. I also thought it would be a good place to hook up a cheap tiller pilot for those guys that are trying to put a AP on their boats.
I think one of the best aux tillers I have ever seen was offered by one of the MAC dealers - he ran a post from the cockpit down to one of the rudders so you could steer the boat with a tiller in the cockpit - a great idea for taking advantage of the cheaper auto pilots too.
My desire was for an alternate helm that I could use to steer the boat also, but my use was for bad weather to stay dry so being in the cockpit did not interest me.
Highlander came up with the stick drive. Here is the link he gave us:
http://www.boatstoreusa.com/steering/ez ... model-840/
