kurz wrote:BOAT wrote:kurz wrote:thanks. I know that the ev-100 can steer by wind information without a chartplotter.
My question was if you can use the raymarine p70 dipslay (that comes with the ev-100) to show the wind direction in a graphical stile. So there was no need to mount the pegasus display an you have the wind information on the AP display. If it would work like that...
Sorry kurz buddy, I did not read all of your message, you want to do without the meter AND the chartplotter as a display - yes you can do that.
It's all automatic - the AP head will automatically put a yellow picture of a wind vane on the course compass when it detects any wind data in the nmea sentences. It looks like this:
Sorry I did not read you message right.
Sorry I am too stubid... But in your graphic, how can you see the wind direction and speed?
Sorry again, first off kurz, the AP head does not care about wind speed, it's not even part of it's calculations to control the heading of the boat so I don't think you can figure out the wind speed from the AP head. We are just talking about a wind vane here. (Actually, I don't ever care about wind speed either - if I really need to know wind speed I can just use my Iphone to take a reading) Wind speed is not very important.
This is how to read the instrument:
On the compass it's showing the forward direction of the boat is 300 degrees.
to North then is in the starboard or GREEN section of the compass rose, and
to West is on the Port side of the rose in the RED section.
On the compass rose itself you will see the wind indicator -
it is a yellow circle with a picture of a wind vane inside it. Right now
the wind is at 260 degrees.
At the very top you can see the rudder indicator - it shows that the AP is
currently putting 5 degrees starboard trim on the rudders
Right under the rudder indicator on the left side it says WIND and on the right side it says
38'P
That tells me that the wind is 38 degrees off my PORT bow.
So here is what I can gather by looking at only this instrument alone:
The boat is on a port tack - it's just off a close reach with the wind 38 degrees off the bow. Now, the head instrument does not care about the anemometer but even without a wind speed indicated I can tell the wind is pretty strong because the AP is adding a 5 degree starboard rudder so that tells me the boat is trying to round up. This is what my indicator would look like if I were in 19 knot winds heeling about 38 degrees.
MikeFloutier wrote:
1. As BOAT says, . . . . on long legs, which the mast doesn't rotate.
2. The AP doesn't need absolute wind direction, just the shifts, hence calibration is a non-issue, since a 10 deg shift from 090 is the same as a 10deg shift from 270.
Everything you said sounds fine Mike except I never said that my mast does not rotate on long legs - in fact it does. If I am pointing very high with the traveler opposite of the boom and the headsail sheeted to the cabin tracks and the boom vang hauled down really tight the mast will come off it's stops and hover. Just wanted to clarify that.
Also on number two there: I can't agree or disagree with that statement because I do not think it's correct. MY pilot follows the actual degree of the wind on a compass rose, so absolute wind direction is part of the course calculation to destination. It has to be, or the boat would never reach it's waypoint.
