Macgregor 26x steering limits
Herschel
Re: Macgregor 26x steering limits
Post by Herschel »
My rudders:
sailboatmike
Post by sailboatmike »
Herschel wrote:
paul I wrote:
Goldenist wrote:And I still need to figure out what's bending these brackets up .. that is not normal right?
I'm sure it helps and is better to disconnect the engine while under sail but I don't think thats the problem.
Steering In those conditions was doable but it probably took literally 10x the physical effort of any other point of sail.
Maybe not tying down the rudders brings the force upwards, pushing the brackets up...
If I don't tie down the rudders they just ride up toward the surface of the water. I never noticed any increased steering effort. Maybe it just never happened to me at the point of sail you are referencing.
My experience with my old style (1998) rudders is that they absolutely need to be tied down all the way or steering is very poor. Also, in a hard turn with the rudders more parallel to the surface of the water my prop will chew a hunk out of the blade. Go ahead, ask me how I know! :P
We could compare prop marks on the rudders, the big prop on the 75Hp makes a nasty gouge in them
Herschel
Post by Herschel »
Comforting, in that "misery loves company" sort of way, to know I am not the only one that experienced such a mishap, but, hopefully, our sharing our experiences will prevent many more. Mine happened when trying to back off an unexpected grounding, and I let my rudders "float up" to minimize draft, but did not take the time to pull them all the way up. I made a full turn to back the boat back toward the channel, and "chop"! :x
DaveC426913
Post by DaveC426913 »
Yup. Rudders gotta be cleated off hard.
I can instantly tell if a rudder has started to rise, as the wheel fights me, and steering becomes impossible.
Goldenist
Post by Goldenist »
Thanks guys.. can't wait to see!
Goldenist
Post by Goldenist »
As a follow up, my difficulties 100% were coming from not securing the rudders in the down position. Feels like an entirely different boat. One that I have MUCH more faith in! Thanks.
sailboatmike
I would be checking your brackets VERY carefully for cracks if they have been bent and straightened, The cast alloy brackets on the early X's are very brittle and prone to breaking at the best of times
Goldenist
Post by Goldenist »
Thanks mines a 2003!
Herschel
Post by Herschel »
sailboatmike wrote:I would be checking your brackets VERY carefully for cracks if they have been bent and straightened, The cast alloy brackets on the early X's are very brittle and prone to breaking at the best of times
I have heard this often, but I have the original brackets. Grounded maybe 5 times in 14 years, mostly mud, but one hard sand. Bent one of my brackets; took it to a machine shop and got it straightened, and we are still good.
JotaErre
Post by JotaErre »
I think you should reduce your sails (furl 1/3 or 1/2 of the genoa and reduce the mainsail too)... probably you'll find the boat much easier to steer.
