DaveC426913 wrote:DaveC426913 wrote:
Next windy say I'm gonna take SeaSaw out and try furling in the jenny just about 10%.
*sigh* and yet Roger himself says otherwise:
If the boat wants to round up into the wind, unroll a bit more genoa, or let the mainsail out. This will move the center of pressure on the rig forward, and make is less likely to round up into the wind and waves
http://www.macgregor26.com/photo_galler ... eather.htm
Yes, that is correct - there is a lot more weather helm on my boat if i use only the main sail. That's why I always start adding back in some genoa from the furler after I reef the main.
It looks like in the pictures where the boat is close to shore they had the genoa fully furled but in the pictures where they are further out to sea they have some genoa out.
If that is true, then this is what I can surmise from the pictures:
A. my guess is that they headed out of the harbor on a reefed main with the genoa furled. The top of the main is at the genoa hound - that's the first (and only) reef point on the stock factory sail (I have one)
(Don't we all reef our main in the harbor when it's really blowing??):
I know those waters and that picture looks just like the rock outcroppings at Brighton Ave between Arch Rock and Little Treasure Cove - at least that's what I think it would look like back in 1999 or so.
If I am correct they are only 4000 feet south of the Newport Harbor Mouth in this picture and probably less than 2000 feet from shore - it's really quite a blow!
B. The boat started getting more weather helm the stronger the wind got and further out they got:
The front of the boat is high - that means a lot of force on the aft - in a blow you want the front of the boat to be LOW so it cuts in and tracks straight.
C. So it looks like they added in some genoa as they got further out and the wind got stronger.
I can't add anymore pictures because Heath only allows three pictures per post, but, I think in most of the pictures in the bad stuff the boat is nosing down into the waves - that's what you want. I would need to go back and review the video to see the boat in the water but I would assume their best sailing was probably with a little head sail out pulling the front of the boat down and into the waves and making it track straighter thru the chop. Don't know - we would need to ask Captain Mike Inmon to get the skinny on how he piloted this weather. I suspect he was probably a little uncomfortable out there even though Roger seems to think that the little boat was dryer than the big boat. It's still pretty scary I would think. Maybe Captain Mike will tell us about it some time.
