I would think that there r water tanks avail with built in baffles to stop the water from sloshing around ?
Generally the initial pump and one re-pump does it to empty the tank.BOAT wrote:I'm starting to think your system is the best. This leads to some questions:
1-Does the ZODI water pressure last a long time under pressure or do you need to re-pump it to complete a shower?
I don't see why not. I use a propane stove, so it's probably a bit faster, but you're really only heating it to 110 degrees or so, not to boiling. I'd skip using the propane burner that comes with it, since it's not terribly stable on a boat.BOAT wrote:2-Can I heat the ZODI on my one burner stock alcohol stove in the boat? (I will buy the one with the propane burner but I don't always want to carry propane).
I have no idea - never did it on alcohol - but on a propane it's about 5 minutes at most.BOAT wrote:3-How long does it take to heat up on the alcohol stove?
Yeah, we don't really use hot water that often, either, and this does the job nicely. It can also be used for washing off feet, cleaning up around the deck, rinsing the anchor locker, etc. since it's so portable. We stow ours under the aft port seat, next to the galley (where the factory battery would normally be).BOAT wrote:I actually counted for two days on board how many times we needed hot water and I was shocked at how seldom we need it. I think a manual pressure tank system like yours may be the best answer.
Well, (and I mean WELL) because the trick your calling out means well like in MOTOR WELL. I already know that trick and there is a much easier way to do it without drilling a hole in the DB well. - Instead - use the MOTOR well.Nauti Nell wrote:In dealing with a place to drain gray water I would think that some sort of pump out to the center board trunk might work. With a little cleverness and discretely routed hoses (think Hogans Hero's) the storm troopers may not notice......
Do you have a source for the "variety pack" of rubber plugs? Those are just the ticket for an onboard Damage Control (former Coastie...I can't stop using the jargon) emergency kit!BOAT wrote:I keep a lot of rubber plugs on board of various sizes:Nauti Nell wrote:In dealing with a place to drain gray water I would think that some sort of pump out to the center board trunk might work. With a little cleverness and discretely routed hoses (think Hogans Hero's) the storm troopers may not notice......
Mainly for emergencies, like they do on submarines - if you spring a hole cuz a thru hull pops you pound in one of these guys and lash it - also works if your vent plug breaks, or you poke a small hole int the hull.
Anyways, I keep a lot of them on board and the small ones will plug up the motor well (and the sink too!).
