So the gooseneck fitting came off the mast?Dave U wrote: ... Any advice on the use of stainless steel screws?
You're limited to rivets, sheet-metal screws, or tapping the mast. If you feel the mast's wall thickness is ample, I guess tapping for machine screws isn't any worse than the dozens of other places that stainless threads are left to interact with the aluminum. (If the problem recurs, you could always shift the boom up by a few inches and drill it again)!
Is is feasible for a backyard, lone-ranger to source (rent?) a commercial-duty rivet-gun?
