A battery pack is a better option if you live in cold country with a few cars as it’s faster than waiting for AAA
I use my pack to pump out the tender after rain, with a portable bilge pump
I can easily carry the pack ashore and charge it at a power plug on Cape too.
I got rid of the springy cord Mercury gave me and replaced with stiff cord which pulls much better.
Does everyone know how to set an engine onto a compression stroke to start with a cord or has that knowledge been lost by electric start mowers?
My 50 starts with one pull, I’m not tiny but I’m not a weightlifter, either.
Pull starting a merc 50
- dlandersson
Re: Pull starting a merc 50
Thought this thread was worth a bump.
whgoffrn wrote: ↑Sat Apr 28, 2018 8:15 am Just curious if anyone has any creative mods to make this more practical...... I've pull started my merc 50 a time or two while it's on the trailer and me standing back behind it on the ground but I've never been able to successfully pull start the engine out in a rolly ocean in the boat .....it seems the steering wheel is in the way to give a good long solid pull and I end up smashing the back of my arm or elbow on it or the angle is too high which pulls the rope off of the flywheel ..... I know ultimately the goal is to not have to and I have solar panels and a generator but I would like to have that option as a true viable option (just in case) .... I considered bolting up some kind of pulley at the proper angle height so the rope wouldn't slip off the top and running a longer rope so I can get away from the steering wheel...but thought I'd ask here first to see if anyone else had made some creative way to make Rogers idea actually work while out on the water
