makeshift whisker pole
DaveC426913
I sailed the whole way home today on a dead run, so I played with fashioning my boat hook into a whisker pole to hold the jenny out (either behind the main, or wing-on-wing).
I'm thinking about making a better solution - one that hooks onto the clew all proper-like, not with bungies - and attaches maybe to the cabin-top track. Doesn't need to attach to the mast.
It would be awesome if I could deploy and ... ploy? ... the pole from the companionway. Then I could tack it easily without the fuss and folderol of going forward.
Anyone made such a contraption?
- sunshinecoasting
Re: makeshift whisker pole
I don't worry about a whisker pole, I find if it is a true downwind run (which I love to do) then the wind flowing off the main holds the headsail in place, the best way (and safest) to do that on an
is to remove the main sheet from the centre console and clip it to the life line loop on the rail just rear of the cabin, that way the main stays where you want and removes the risk of an accidental gybe. Works a treat.
DaveC426913
Yup. I clip the main onto the "armpit" too.sunshinecoasting wrote:I don't worry about a whisker pole, I find if it is a true downwind run (which I love to do) then the wind flowing off the main holds the headsail in place, the best way (and safest) to do that on anis to remove the main sheet from the centre console and clip it to the life line loop on the rail just rear of the cabin, that way the main stays where you want and removes the risk of an accidental gybe. Works a treat.
Still, my 150 jenny spends much of its time limp.
Because my usual trip from harbour to island and back is several hours each way, the extra effort to catch max wind makes a big difference.
U could try one of these on the jib track see if it works for U !
https://www.westmarine.com/buy/schaefer ... cordNum=38
https://www.garhauerstore.com/track-blo ... sc-l1.html
or check pricing at fogh or genco or HMP
DaveC426913
Yep. That's the plan.Highlander wrote:U could try one of these on the jib track see if it works for U !
Whisker poles are incredibly expensive.
I'm hoping that the way I'm using it counts as 'light wind' on a 'small boat', so I can buy a $200 one. I'm not spendin' 500 or a 1000 on one.
I'll probably start with a jerry-rigged boat hook, and see if it doesn't kill me.
Wayne nicol
i got a fiberglass paint extension handle - its probably about 1.5 to 1.75" in diameter and telescopes in half, was very affordable.
i epoxied in a wooden plug at each end- then drilled through, and a very snug and short lashing to a snap hook
works very well!
works very well!
Here,s the boat hook / whisker pole mod link that I copied & made works like a charm instead of 3 sheet metal screws I tapped the treads #8 or # 10 & used threaded screws
http://www.macgregorsailors.com/modt/index.php?view=436
I also have a whisker pole so as I can fly my genny & jib wing on wing at the same time
Ok Dave.
This is what u r talking about doing
Boat hook mod to whisker pole
not sure why u think this is any easier than a mast mounted one as u would still have to go forward to unhook it as u would not b able to swing it back too the cockpit because the shrouds r in ur way even if u put it above the life lines which u would have to do anyway
DaveC426913
Yup.Highlander wrote:Ok Dave.This is what u r talking about doing
Yeah. I'm realizing that.Highlander wrote:not sure why u think this is any easier than a mast mounted one as u would still have to go forward to unhook it as u would not b able to swing it back too the cockpit because the shrouds r in ur way even if u put it above the life lines which u would have to do anyway
I was hoping I could reach the track car from the companionway, pull it in, detach from the clew, tack, then reattach from the companionway.
But frankly, that might end up being harder than just leaving it attached to the mast and swinging it over.
I hate having to go to the mast when single-handing. My auto-pilot (bungie) won't work for that long.
When you backwind them the make an amazing sound like a carrot snapping...
Ah I think someone has snapped his boat hook whisper pole on his GennyCatigale wrote:When you backwind them the make an amazing sound like a carrot snapping...
