I want to put a trailer on the beach and use a winch to pull the trailer up and down the beach, so that I can dry dock the boat all the way up the beach near easy access regardless of the state of tide. I have never seen this done before and wondered if anyone else has seen this being done and had any references about it. Or could point out what I might be overlooking in this plan? The beach is about a 10 degree slope, and fairly smooth but with the occaisional rock and a very few boulders that I'm pretty sure I can avoid.
I imagine that I might have a clothesline loop of rope/cable from shore to mooring, attached to trailer, and upon arrival, pull trailer down the beach into the water, motor mac onto trailer, and then winch the trailer and boat up the beach above high tide to a standard parking spot from where it can be easily loaded and unloaded. Departure is reverse, lower trailer and boat down beach into water, launch, then pull clothsline to put empty trailer back up beyond high tide on beach. Does this make sense? What am I not taking into consideration? Why haven't I seen this done before regularly?
Any trailer used for this will need to be extremely corrosion resistant, and likely would need to be able to be pulled from both directions to avoid swapping ends going up and down beach. The trailer may never get rinsed with fresh water, and just live right above the surf zone.
Alternatively, the trailer could be made to float, and be tied off at the mooring. Upon arrival, just drive the mac onto the trailer/dolly, and then drive the combo onto the beach, then winch it up the beach. A floating dolly would probably become completely encrusted with marine life and seaweed and kelp, creating problems if left floating all the time. Pictures below show the lot at high and low tides.
Any observations?
