Hooky
Posts: 7 Joined: Sat Aug 02, 2008 5:01 am
Post
by Hooky » Fri Apr 17, 2020 4:11 am
Posts: 6698 Joined: Tue Feb 01, 2005 7:28 pm
Post
by NiceAft » Fri Apr 17, 2020 4:45 am
That is beautiful work.
What is the heat source for the stove, gas or alcohol?
Posts: 8299 Joined: Thu Oct 11, 2007 12:01 pm
Post
by Russ » Fri Apr 17, 2020 6:05 am
Wow, that is beautiful work.
I'm curious where does that drain hose go to? A thru hull?
Posts: 3402 Joined: Sat Jul 18, 2015 9:52 am
Post
by Jimmyt » Fri Apr 17, 2020 6:30 am
Very nice! A lot of useful storage created with that. That will make the galley area so much nicer to use!
adudinsk
Posts: 495 Joined: Tue Aug 27, 2019 12:53 pm
Post
by adudinsk » Fri Apr 17, 2020 8:56 am
Nice Work!
Hooky
Post
by Hooky » Fri Apr 17, 2020 5:01 pm
NiceAft wrote: ↑ Fri Apr 17, 2020 4:45 am
Alcohol stove
Hooky
Post
by Hooky » Fri Apr 17, 2020 5:03 pm
Russ wrote: ↑ Fri Apr 17, 2020 6:05 am
Hi Russ, it’s a thru hull, I extended the cupboard floors a sides and glassed them direct to the hull
Greek_sails
Posts: 1 Joined: Fri Jan 08, 2021 3:27 am
Post
by Greek_sails » Fri Jan 08, 2021 7:18 am
This is very nicely done, did you add it on the original galley? I purchased one recently and it just has plastic drawers so I am thinking of doing something similar to what you did(if it is on the original), but due to the lockdown I cannot go to the boat do you happen to have the measurements of the inside?
Greek_sails on Fri Jan 08, 2021 11:49 am, edited 1 time in total.
Inquisitor
Posts: 926 Joined: Mon Apr 23, 2007 5:24 pm
Post
by Inquisitor » Fri Jan 08, 2021 7:31 am
I've never been inside an X. Is that mods to the original galley or a completely new one. Either way, it looks so much nicer than the stock M galley.
I gather the X doesn't slide???
ris
Posts: 703 Joined: Sat Feb 28, 2015 4:27 pm
Post
by ris » Fri Jan 08, 2021 7:08 pm
The X galley is fixed in place.
Richard
kurz
Posts: 1304 Joined: Mon Dec 06, 2010 9:07 am
Post
by kurz » Sat Jan 09, 2021 3:41 am
Cool. I like the white color!
OverEasy
Posts: 2873 Joined: Mon Sep 28, 2020 11:16 am
Post
by OverEasy » Sat Jan 23, 2021 11:36 pm
Wow! Nice work! Simple ,clean, even elegant!
Democritus
Posts: 63 Joined: Tue Oct 13, 2020 3:58 pm
Post
by Democritus » Mon Jan 25, 2021 11:15 am
Beautiful! So much more usable space!
What are the grates under the table for?
Vince
"Spiraling Shape" 2002 26X
Tohatsu MFS50A
C Buchs
Posts: 605 Joined: Thu Apr 23, 2015 6:49 pm
Post
by C Buchs » Mon Jan 25, 2021 1:02 pm
To open your drawers, I see you have a latch that you reach through the hole to operate. Can you post more information about what latch you used?
Jeff
OverEasy
Post
by OverEasy » Mon Feb 22, 2021 10:52 pm
Hi!
Beautiful galley mod! Nice job!
Now how do I keep this hidden from my wife ........
Opps, too late!
Guess my dual battery/wiring upgrade/new chart plotter/triple bilge pump install project just got a galley upgrade feature.
Fun times full speed ahead........
