Ordered via Amazon, it's now $120, and it fits perfectly. Only other flaw had been the new EPA gas cap, but I found the old cap via Walmart and ordered 3, thinking I'd probably use a 6.5 gallon tank as a spare, leaving room for the engine battery in the opposite compartment.
Now to fuel lines. Having built an experimental aircraft, fuel lines run through the cockpit to the fuel selector valve, then through the firewall to the engine. I'll be running the fuel lines through the cabin, along with the battery cables. If it works in an airplane, I'm comfortable using in a boat.
We moved recently and just got the boat into it's new home. It's a 2013 26m, never been rigged or in the water. Looking at a Yamaha 60hp and need to add the other items to get it into the water, radio, life jackets, anchor, etc.
BOAT, bring out another thousand
Jake
