I'll check every connection.
I'll check the battery - see if it's dead. If so, I"ll disconnect it.
Is there anything I can do to root out any alternator problems?
Not charging the battery, of course.
Does the "oil pressure" light come on once it's running, and is it off when not running with ignition on? The oil light should be on when running, but the "temperature" light should be off.DaveC426913 wrote: ↑Tue Aug 18, 2020 5:10 pmThe only thing left, I think, is the low oil pressure sensor.
