I would normally winch the main halyard up tight. With the v young and inexperienced crew, I admittedly didn't make any attempt tighten the halyard beyond pulling it firmly by hand. When I've got at least one experienced crew member and wind below 20 mph, I'll go play and see how she sails. I will install a turning block at the mast step pivot bolt and I already have a 2 rope clutch ready to install for the halyard so I don't have to hoist from the mast. There are lazy jack lines on the mast that need newestretch cord l. I also plan to install a spinnaker halyard higher on the mast so I can use my assymmetric spinnaker from the other boat.Tomfoolery wrote: ↑Sat Oct 10, 2020 9:06 am If you want to reduce heeling, get new sails. Those look original, as are mine, and old, cheap sails give as much heel as drive.
Also, that open spot at the tack fitting looks like the foot is too far forward, and/or the sail isn’t hoisted all the way. You have sail slides, which weren’t OEM, and they bring the sail back a bit from the mast. But the tack fitting also has to come back to match. I drilled a hole in the boom slot and reattached the tack fitting there, so the sail is flat in the tack area.
There’s a post or two, or an entry in the mod section, where I went through the process. If you feel like looking.![]()
I didn't realize the tack hook needed to be moved back... what you're saying makes sense to me. I also think the bolt rope has shrunk by a couple inches. My 26D does not have a tack hook so that's a new piece of hardware that I don't have experience with.
I know these sails are kinda beat, but my old boat will probably get sails replaced first. For now, I just want to put on some miles and get a feel for the X. I don't have any expectation of the X sailing nearly as well as my 26D. Maybe if I spend $1500 for new sails and another $1500 for a windward sheeting traveler, a set of T track cam cleats, and a pair of worthwhile self tailing winches. New running rigging should be on the list too. Maybe I'll stumble on some great used (or new) sails for a bargain someday.
For now, I'll just clean up the boat some more, figure out the systems a little better, and just have fun playing on it. The new boat was a heck of a bargain that I impulse bought and now I'll need to share my boat bucks budget between the 2 boats. I'm really glad both vessels are good enough to be used as is. I'll make improvements a bit at a time, starting with rebedding hardware and replacing windows to stop leaks on the X.
