I next tried with products I had on-hand around the house on a bad area of about one sq-foot. I used a clean rag and some SoftScrub with Bleach. This got all the lichen and tannins cleaned off fairly easily. I was actually surprised. I then used some Meguiar's paste car wax. This seemed to work so-so. It looks ten times better than before, but not the wet-glass look. From what I used, I could probably do the entire boat with about $10.
I pretty much decided on getting a dual-action polisher that I can justify the learning curve on the boat before using it on my cars and started watching YTs. The unbiased ones are on cars. When it is on boats, its invariably someone plugging ten different products that will run several hundred dollars on top of the tools. I'm getting lost in all the jargon, different brands. hull, plugging Meguiar's in gets me at least 42 different hits of polish, glaze, wax, correction compound, buffing compound. Different pads (colors representing coarseness I'm guessing????) but every brand uses different colors schemes. Polishes - It seems like I might need one to get the worst cleaned-up (lichen and tannin) and then one to smooth it out... but then which polish goes on which pad becomes the next issue. After that, I then need another pad for applying wax... and then another to buff the wax. I'M TOTALLY LOST IN THE WEEDS!
Then I run across this product...
... that seemed to win many "Top-10 Reviews". But again being the Internet... a grain of salt is required. But it says its a one pass job... clean, remove chalk, polish and wax. But at $40 it damn well be a lot better than $4 SoftScrub.
I'm looking at the Bauer DA polisher and they have four pads: Blue: Foam Cutting Pad, Yellow: Foam Polishing Pad, Green: Foam Buffing Pad, White: Foam Finishing Pad.
I think my question starts with:
1) Is SoftScrub w/ bleach considered toward the course/cutting or fine/polishing end of the spectrum?
2) Which polishing pad should I use with SoftScrub?
3) Would the 3M or other product(s) be better?
4) Which polishing pad should I use with those product(s)?
