Well thank you all very much for the encouragement and praise
Regarding the centerboard and rudders, nope, didn't have them down at all, at any point, including attempting to intercept the trailer.
In fact the rudders were still bolted in place, to ensure they didn't fall down while towing
OK, I'll have to experiment a bit with the ropes, figure out just how they are supposed to be connected for the rudders. I don't seem to be able to find any suitable hitch pins locally. Might try drilling a hole through my existing bolts and then putting the clippy bit through, as I can find the clips locally, just not the thicker part. Main thing is it's good to know I can use the rudders!
I was pretty sure I'd read somewhere someone mentioning they used the rudders for slower-speed steering, and yeah, I think that's a necessity
Had a closer look at the steering, not the actual stuff but just trying it again at home. First thing I noticed was that the engine was able to flop from side to side far too easily - it was actually entirely disconnected from the steering! Must have bounced free on the way home, as we didn't do any kind of tying up on the way back
(as an aside, the guy at the local boat club who drives the tractor to get you in and out of the water, well let's just say he has an attitude problem, so we didn't hang around.)
I find a little ball thingy and was able to reconnect it. After that I could see the rudders do actually move quite a lot, so I think for sure the steering will be WAY better with the rudders down. Obviously rudders only work when moving through the water but if it's actually going where I'm telling it to then I'm happy to be quite decisive and bash it onto the trailer firmly. On this occasion I realized I had no real control so just cut the engine and jumped overboard to try and manhandle it onto the trailer.
(The tractor guy said you shouldn't cut the engine until it's on the trailer, but that rather presumes the engine would be of any actual use at steering, which it clearly wasn't! I considered the prop more of a hazard then a help and so stopped it)
Jumped is the wrong word, more like clambered and squeezed through the pulpit, climbing onto the trailer hitch, before jumping into the mud.. I've ordered a rope ladder, which I'll tie onto the bow railings. This trailer is not original and has no ladder, so unless you want to go swimming to the stern ladder there's no sensible way of getting onboard while launching.
As I mentioned, there is no jetty here but Tractor Guy was adamant that untying the boat from the trailer is not his job, so at least one person - me - has to be outside the boat, undo all 4 tie downs in the mud, release the front chain, unwind the winch and then try and grab the bow railings as it floats away, and clamber on. Then run across the roof and to the cockpit to start the engine, put it in reverse and steer away from the pointy spikes that used to be a jetty...
Yet it did reverse, reverse does work, it just doesn't have that instant stopping power of the 200 hp Evinrude I'm used to. Probably me expecting a bit much from a little 50?
I'm very familiar with my old motorboat for parking on the trailer. I know with that to cut the throttle about 2 boat lengths away, a couple of seconds later my own bow wave would lift the rear of the boat and shove it forward, with just enough oomph to plant it nicely, so the trick was to be aiming just right and then let the wave do the work.
With this boat I was aiming absolutely perfectly for the trailer, and yes, allowing for the current, but as I got really close it just decided sideways was more fun and I just could't spin the wheel fast enough or get it into reverse and then throttle fast enough - I just gave up, cut the engine and decided to do it by hand!
One fantastic bright side - my fishfinder worked perfectly! I've got through a few fishfinders on my previous 2 boats, none of them seemed quite right, but this one worked fine. It's complicated though, so I need to get used to all the options.
Really, this 1st trip SHOULD have been a cautious affair and all about testing things, but it was really taking my father in law fishing , my brother in law for a fun day out and of course the Admiral came along. I didn't even get to test putting the centerboard down, as I wasn't 100% sure I'd be able to get it back up again
Didn't test it with and without ballast, didn't test the rudders, couldn't even get to my own fishing gear as all sorts of other stuff on top of it and I was 100% steering or peering at things (such as the thru-hulls from the old toilet, to see if any leaks - nope).
When setting off yesterday I noticed parts of the trailer were very low, only about 4 inches from the ground. Just adding water to the head, under the sink, plus an icebox etc seemed to flatten the tires a bit and so today I've been under the boat with my angle-grinder, cutting those sections off. They were excess for the adjustable rollers, so not needed but could be a real problem if finding a speed bump or similar. I'm now filthy dirty and need a shower, and this is already a long post, so i'll shut up for a bit
Forgive me for being so lazy, but anyone happen to know the part number for a Honda BF50 thermostat, circa 1996? I have a PDF manual but that's 2002, 6 years later, and Honda tend to change things. And the manual doesn't mention the part number anyway.
