Guyc wrote: ↑Sun Mar 07, 2021 9:37 am
Great post Startscream. I’m right across the St Lawrence river from you (the boat elevator post) and want to thank you for your pictures as I’m about to install the very same. Luckily enough, my Evinrude install put the tachometer way down in the pedestal so I’ll have room to put the P70 right just below the steering wheel where the pedestal is angled.
While I’m at it, seriously thinking about adding a Raymarine MFD. Hesitating between the Axiom+7 with Realvision (pricey but more features) or the Element HV. I confess that the new sonars’ ability to create a 3D picture of what’s underneath the boat has considerable geek appeal, not to mention the ability to control the autopilot from Navionics route, iPad replication, etc. Worthy of further discussion no doubt.
For my EV100 install, I’m thinking of putting the backbone and possibly the Ac 100 inside the pedestal, on the bow side wall. I think it would fit and might simplify wiring. What do you think? Would avoid buying an extension for the MFD which apparently comes with a measly 4 ft cable. I already have 12V in there. Another option would be to put the Ac100 inside, underneath the starboard winch, close to where my vintage Eagle depth/fish finder currently resides. Could reuse the power line (not fond of running cables when it can be avoided). Was also contemplating putting the ev 1 there as well (more cabling laziness) but worry about potential interference. Thoughts?
Thanks!
I'm waiting for BL Yacht in QC City to deliver my 14 gauge tinned two-conductor wire to finish the job, it's the only thing that's missing to power up the ACR.
The major decision is where to put the wheel motor: if your tach is below the wheel (like mine is) you'll have the same problem that I do and end up with the clutch lever in the aisle between the pedestal and the seat. I recommend spending some time thinking about this to see if you can find a better solution. If you want to see my install you're welcome to wait until we get in the water in April/May and come see it at the PCYC, or if you want to take a road trip to the North Shore you can see it on the trailer any time. It never snowed in this year so I've been able to work on it year-round. Very likely you'll need that M14x100mm bolt, and I have a few spare SS nuts you could have for it.
I thought about the P70 on the pedestal, and the Axiom 7 as well. (BTW, if you are going with the Axiom7 have a look at Defender: even with import and freight fees you'll save hundreds vs. buying it locally, as much as I like supporting local it's a bit of highway robbery.) The reason I didn't mount it there is because of the mainsheet. By law, the mainsheet has to wrap around anything and everything, so to keep the P70 safe I put it in the rear of the cabin-top. I think that's going to make it easier to adjust while underway, because while I'm using the autopilot underway it's unlikely that I'll be at the wheel: more likely I'll be tucked under the dodger. The Axiom 7 is probably going to go on the opposite (port) side of the cabin top. Yes, for the Axiom 7 you have to buy a backbone extension, and an NMEA to SeatalkNG converter cable, which adds to the overall price. The Axiom 7 doesn't have a SeatalkNG spur. I also want the 3D sonar transducer, but I'm going to wait until NEXT christmas.
The pedestal isn't waterproof, so I didn't want anything other than wire in there. I like having my expensive electronics inside the cabin, even though the components are water-resistant. It certainly would simplify the wiring tho, especially if the Axiom7 is also going on your pedestal. All you would need is a singe power wire. I do recommend a new power wire instead of using the 12V that's already in your pedestal, unless you are very sure of its wire gauge, fusing, and distribution. The factory 12V in the pedestal runs on lamp-cord, maybe 18 gauge but probably lighter, and it won't do for the autopilot.
Wiring new stuff on the X is an absolute beee-yotch. Having the backbone and all the instruments in the pedestal would be great from that perspective. Personally I like the look better in the cabin-top, plus all the passengers can share the info and responsibilities, plus...mainsheet! If the Axiom 7 has to go on the pedestal too, then it's going to be on top of the pedestal and be an absolute mainsheet-trap.
Inside beneath the starboard winch...hmmm...I wanna say that the AC100 and EV-1 won't fit in there with all the wiring. That's just my feeling from fooling around in there mounting the P70, not from measurement. It's not easy to get power wiring up there either: possible, but complicated. You have to go all around the bilges, up inside the head, through the aft head wall and then back inside the headliner. 14 gauge would be borderline for that distance, and 12 would be better.
There are certainly better ways to do it than I did, but if you don't want to add anything else I think I did it just about the easiest way possible. I say that because I don't have to wire the Axiom7 yet: my arrangement is going to make that part tough. I'll have to get a backbone cable from under the starboard winch to under the port winch and that is no small feat to accomplish.
Keep in mind that the AC-100 actually drives the wheel motor, and it needs a minimum of 14gauge wire so re-using other wire may not be possible.
No easy answers, sorry. Let me know if you want an in-person walk thru any time.
