I'm finally resurrecting this thread with some major updates and progress! My rudder post has finally been reinforced and the oversize rudder is finally glassed, faired, barrier coated, and ready to test.
The past couple years, this rudder project got tabled while I worked on a myriad of other projects and otherwise just enjoyed the boat. I don't remember who it was but during a conversation about what I was doing, someone at BWY recommended redrilling and angling my rudder blade forward, so I took his advice and it made a HUGE difference for no cost and minimal effort but I've had this big rudder sitting in the garage 75% finished and I believe the improvement of the big rudder over the angled rudder will be even better so I took the time to better my fiberglass skills and finish this beast.
Pic of new vs old rudders. The stock rudder shows the 2nd set of holes I drilled to angle the bottom forward. I'll stash this rudder under the aft berth just in case.
My rudder post pivot brackets (the 3/8" thick welded tabs with holes to slide onto the pintles) were terribly worn out and I was afraid to add any extra load without replacing the post or reinforcing it. I cut and fit a couple reinforcement brackets from 1/4" aluminum plate and had a local shop weld them to the existing tabs and post. Now there is no more repetitive clunk when turning and I'm not afraid of losing my entire rudder when bashing through waves!
This shows the worn out pivot bracket... notice how out of alignment the tab is and the hole is 11/16" diameter instead of 1/2".
We sandwiched the new and old aluminum tabs together and fully welded and filled the old pivot holes then I redrilled. The original tabs were very far off from being centered on the spine of the rudder post. I used a laser line and framing square to lay out the new hole locations.
With the reinforced rudder post finally completed, I dug out the project rudder and finished laying several layers of fiberglass cloth then faired with west system 407 and barrier coated with 6 coats of west system 422. It could use a final sanding and top coat of epoxy to smooth everything out but it's good enough and further work on it will have to wait until more pressing projects on the other boat are checked off the list.
I learned a lot more about composites work through this project and have gotten better because of it. I'm not thrilled with the weight of this rudder (about 40 lbs!) but it's below the waterline so it should be ok. I'll use the back stay to haul the rudder up out of the water at the ramp. I'm really looking forward to sailing soon and trying this new modified rudder and post!
