Jimmyt wrote: ↑Wed Jun 09, 2021 5:07 pm
You're killing me... I was happy with the modified window unit idea until you threw that "cool on the hook with no gen set" idea in my face...
Don't you hate that when it happens?
In a quiet cove and ten other boats. All is perfect silence. You can whisper and be heard by the boat 50 feet away. Then someone cranks up a generator. The picture is ...
Here is my simplistic (Thermodynamically ignorant) blue-sky concept.
As anyone who knows of even one of my projects... cutting and drilling in the boat doesn't bother me much, until... it goes from inside to outside. Through hulls freak me out. Water stays outside... good water. Water gets inside... bad water. No holes... no bad water.
Condenser
Some ages ago I saw a sailboat with a simple U-shaped loop of copper tubing under the hull. Stretched out it couldn't have been more than 2 feet long. It was obviously for cooling. Don't know if it was engine cooling or some kind of refrigeration cooling. But it instantly made sense in an ugly kind of way. In my speed freak days, I said no way am I going to have that dragging in the water. Now, I'm thinking how brilliant... no costly, maintenance prone, pump-driven water heat exchanger inside the boat... just hang the actual coil in the water. I would certainly need your guidance for length needed. If short enough, I can imagine going out the hull on the transom above the waterline and drape down below the engine. No bad water.
Compressor
Under the steps, next to the battery. Short electrical runs, insulate for quietness... easy peasy.
Evaporator, Expansion Valve
Place in M's floatation space around the anchor locker. Can drain out anchor locker drain... OR better yet, filter and drain into fresh water storage under V berth. Uses a couple of computer fans for air flow.
Lot's of insulated copper tubing running the length of the boat... but the loudest noise would be the compressor under the steps... IOW the whole system will be almost dead quiet.
Aft Berth Design
Those using the aft berth as the master have it easier. Could probably hang the whole kit and caboodle on the inside of transom and blow over your feet.
... OR... Did I just NASA this thing to death?
