Hi welcome aboard
The toppin lift is only a line 3/16" Dia. line 31' long low stretch line go to any marine store & buy some, don,t buy cheap line from a hardware store it,ll only last a yr if u r lucky , on top of the mast u,ll see a eye becket strap hoist or just a 1/4" bolt sticking out near the top of the mast tie the line onto that & tie the other end onto the end boom cleat most guys make a loop about 18"-24" from the bottom end of the line so as u only have to lift the boom up & hook the looped line onto the boom cleat, but that depend on how high ur Bimini is or how tall u r ?. the topping lift must b loose at all times while sailing otherwise u won,t b able to adjust the mainsail leech with ur mainsheet vang & boom vang
as for ur Boom vang u can buy one from BWY
https://shop.bwyachts.com/product-p/3301-1m0.htm
or use ur old original mainsheet vang for a boom vang , then up-grade to a ball bearing mainsheet vang !, these guys make quality equipment I,ve bought all kinds of stuff from them I replaced all my Jib/Genny cars with ball bearing units & halyard pulleys & blocks all ball bearing from these guys , but if u can buy something else cheaper locally with ball bearings ur choice a hint tho if u replace & up grade ur mainsheet vang don,t buy one of those nice shiny S/S one,s on a sunny they they will reflect the suns rays into ur eyes blinding u & eventually giving u a headache go either gray or better black foe no reflection
https://www.garhauermarine.com/shop/page/2/
if u don,t already have a boom bale on the boom u will also have to buy one unless u buy one from BWY, the holes r already predrilled in the boom for u
If u have women crewing ur boat they will appreciate a ball bearing mainsheet vang
