Trailering, stepping, raising the mast with a furler
Re: Trailering, stepping, raising the mast with a furler
:D :D :D
Highlander wrote: Sun May 22, 2022 10:07 am
dlandersson wrote: Sun May 22, 2022 10:00 am Ditto 8)
Russ wrote: Sun May 22, 2022 8:58 am The older I get the more I'm convinced I'll never go back to hank on jib.
Staying off the foredeck of a small bouncing boat is so much better.
Oh, the purists will have other opinions. But I'm not a purist.
X3, because when u git to my age it,s not the boat doing most of the rockin & swaying it,s Me :| Jez !
kenfyoozed
Sailboat: MacGregor 26D
Post by kenfyoozed »
Jimmyt wrote: Sat May 21, 2022 9:08 pm Yes. I knocked it together to replace the metal crutch that the previous owner used...
https://macgregorsailors.com/mods/index ... em&id=2119
Thanks, I am sure I will borrow this idea.....
Be Free
Post by Be Free »
Highlander wrote: Sun May 22, 2022 11:22 am
Be Free wrote: Sun May 22, 2022 11:06 am A hank-on jib with a down haul led back to the cockpit will keep you off the foredeck as well. Before that I had a rule that crew could only strike the jib standing in the foredeck hatch in rough weather. No one goes on the bow in rough weather!
True but as long as that sail is still on the deck the leach flapping away it,s taking a beating , but better than Havin to worry about MOB !
& U singin Oh come back ,Oh come back to Me ! :P or being dragged along as shark bait ! :?
The down haul runs through a rope clutch and does a pretty good job of holding it down. I pull the jib sheets back to where the clew is pointing directly at the mast base and lock them down. That cuts out most of the flogging.
Bill
2001 26X Simple Interest
Honda BF40D
Stickinthemud57
Post by Stickinthemud57 »
You might want to check out my mod that uses the trailer winch to raise/lower the mast. Keeps your feet on terra firma and yourself out of harms way.
https://macgregorsailors.com/mods/index ... em&id=2149
